Question about Samsung SlimFit TX-S3082WH 30" TV
No blue color on tv screen
I have a Samsung [email protected] that I purchased maybe 16 months ago and the blue color has not appeared on the screen since yesterday. Everything is red and green. I have turned on and off the TV and tried different channels, and checked the same model tv downstairs. It is definitely this particular TV. What's causing this and how can it get fixed? Thanks in advance.
Posted by ciscoe333 on
  • ciscoe333 May 01, 2009
    Thanks for the tips. I just double checked the lines in and out of the cable box and tv, and the blue cable on the cable box was slightly out. I hadn't noticed the first time I checked those. Must be the cat that likes to jump up on the box and sleep there to keep warm... sometimes making the box slip when he jumps off again.
    Many thanks. It's so nice to see full color again!
  • Mike Matkovic May 11, 2010
    How are you connected to the TV ? Component cable ? HDMI cable ? Seems like you might be using a component cable and the blue wire is loose or bad. Try connecting the component cable to another component input on the TV, then switch the TV to that input. Let me know..
Mike Matkovic
    Scholar:
  • 125 Answers
Your welcome ! please comment. Thank you !
Posted on May 02, 2009
I have a LG 32inch Flat Panel LCD that I purchased 2 years ago at best buy in canada. About 6 months ago periodically I would see vertical strips of see thru blue appearing on the screen. That continued...
The T-CON (Timing Control) board on the panel is/has failed. If it is available, it can be replaced. If not, the entire panel will need to be replaced to correct the TV.
May 07, 2010 | LG 32LG30 32 in. LCD HDTV
Samsung HLN617W DLP 61" TV only show green color
BINGO! Light Engine, Maybe listed as- Assy Engine Go to website Encompass Parts Distr their you will find what you need or Call 1-800-638-3328 ,or Try UED 1-800-648-6657
Dec 01, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Green shadows appear on new visio SV470VT. Very
It maybe a circuit control board for the screen. Last thing you want to do is void the warranty by opening up the TV.
Best to use the warranty at this point. Here's info to get you started.
Phone Numbers
Technical Support or To Place an Order
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
[email protected]
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 28, 2009 | Vizio VO47L 47 in. LCD TV
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Blue screen
Check the CRT.and then check if there is a loose solder on the whole board and also check the H-out..change the CRT socket which is Color White Connected to the Tube.
Nov 12, 2008 | Samsung TX-R2735 27" TV
Horizontal Blue Line
WHEN YOU HAVE A SOLID BLUE LINE THAT DOES NOT MOVE...YOU HAVE A DEFECTIVE PANEL...LIVE WITH IT OR REPLACE PANEL..NOT COST EFFECTIVE TO REPLACE PANE....JOE ACE
Jun 13, 2008 | Westinghouse TX-42F430S Television
We have a samsung 50" plasma. When we have alot of the colour blue on the programme we are watching the TV blacks out for about 5 seconds and comes back on Continously whilst blue is on the screen. It...
If the samsung is more than two years old it is probably the Tv. I have a 42" samsung and the color blue will appear all over the tv for awhile and then go away. It started after two months and I just thought it was from playing xbox. I believe its a known defect in the tv or related to burn in. If you got it from a store use your coverage on it
Apr 29, 2008 | Televison & Video
Color bands at the top of the screen - Sony KDF-50E2000
I have the same TV with the same problems. Sony has issued a recall for these tvs. Contact sony and will fix it for free or give you a discount on another tv.
Apr 02, 2008 | Sony KDF-50E2000 50" HDTV
Picture is Psychodelic....
I HAVE A SAMSUNG HD TV MODEL TX-P3064W AND I TURN IT ON AND GOT ALL OF THE COLORS IN PSYCHODELIC MODE. I NEED TO KNOW IF THIS IS AN EASY AND CHEAP FIX?
Dec 16, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at [email protected]
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Samsung SlimFit  TX-S3082WH 30" TV Logo
487 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
