SOURCE: Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
SOURCE: Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
SOURCE: seagate 1tb external hd just beeps
You may want to open the drive and check the internal connections first to make sure none came loose after you have powered it down.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
If a drive is CLICKING after an accident there is a very strong possibility that it is dead or dying. This is known as the "click of death".
SOURCE: I had four broken DVRs of same type, I want to use
If you have a full version of SeDiv you can write back to the drive.
Just edit the vendor track and place the standard password on the place
where your hex password is.
The solution provided entails reading the Vendor Track. You can use SeDiv to do this.
SeDiv Seagate Terminal:
http://sediv2008.narod.ru/Easy1014.rar
English documentation:
http://sediv2008.narod.ru/HelpEn.rar
See this thread:
sediv-hdd-seagate-terminal-for-windows-t11980.html
In order to get SeDiv to run, you may need to wind back your system date to the date stamp of sediv.exe.
You
will need to access the drive via its TTL RS232 port. To do this, you
can use an adapter such as the ones described in this thread:
http://forums.seagate.com/t5/ATA-and-Se ... 036#M19464
SOURCE: Seagate 1TB Hard Drive ST31000333AS The drive spins up, clicks, spins down. not detected by bios.
Right-click on "My Computer"
Click "Manage"
Double-click "Disk Management"
You will probably see Disk 0 and Disk 1 for your primary hard drive.
Go to lower right portion of box and scroll down until you see Disk 2. It is probably your USB drive without a letter. It should show the size of the drive.
Right-click in the left portion of that drive box (Disk 2)
Click "Initialize" and "OK" in the next dialog box. This takes just a few seconds and it should now say "Online" in the "Disk 2" box.
Right-click in the box to the right side of the "Disk 2" box (where it shows your disk drive size and says "Unallocated".
Click "New Partition" and a "New Partition Wizard" will open up.
Click "Next", then select "Primary Partition" and click "Next".
Verify partition size (use entire disk size available unless you are creating multiple drives) and Click "Next".
Assign drive letter ("F" is typical if CD-Rom is E) and click "Next".
Format this partition with "NTFS", "Default", "New Volume" and click "Next".
Then click "Finish" to exit the wizard and start formatting.
Be patient... this can take awhile (it took just over an hour for a 320GB drive).
When done, you should see an icon for your drive in Windows Explorer!
hope this helps
