KitchenAid KCM511OB 10-Cup Coffee Maker Logo
m
mayra torres Posted on Nov 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchenaid coffee maker has sat for a long time with no use!
How would i clean my coffee maker with vinigar or clorox?
Frank Russell
Level 2:
Novelist:
  • Expert 86 Answers
  • Posted on Nov 19, 2013
Frank Russell
Expert
Level 2:
Novelist:
Answers
86
Questions
0
Helped
27420
Points
105
Generally, I'd start with one part white vinegar to three or four parts water. You may need to run it throught the machine a few times if it's badly blocked
2 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 30, 2009
SOURCE: how to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Anonymous
  • 145 Answers
  • Posted on Aug 08, 2009
SOURCE: need manual for pro 12 kitchenaid coffee maker.
Manuals and guides may be located online at KITCHENAID.COM.
In the upper-right hand corner of the site, click on CUSTOMER CARE and then click on LOCATE MANUALS AND GUIDES.
It will then ask you for your model number.
For an espresso maker, the model number is located on a silver sticker behind the water reservoir. For a coffee maker, the model number is located on a silver sticker underneath the machine.
On the website, type in your model number exactly as it appears on this sticker and click GO.
This will then bring up the literature listing for your particular unit. You will need Adobe Acrobat Reader to view the files.
Also, Kitchenaid Customer Service will send you a physical copy of an instruction manual at no charge if you choose to call them. Their toll-free telephone number is:
1.800.541.6390.
How to descale keurig elite 40 coffee maker with vinigar
Unfortunately you will need to use vinegar. The acetic acid in vinegar is strong enough to clean most brewing machines.
Use distilled white vinegar.
Every time I meke coffee my machine have swill sound and don't make full amount of coffee
Many times when a coffee machine is not working properly, it needs to be cleaned. Pour 1/2 & 1/2 White vinegar and water into machine as if you making the coffee, and turn machine on. It make two treatments t clean out the machine. You can then use some baking soda in water to neutrlize the vinigar.
1helpful
2answers
Not enough water is coming through to make a cup of coffee
Try running a gallon of vinigar through the coffee maker. This will help if the issue is caused from hard water buildup.barterjoe_72.png
1helpful
Red light flashes How do do clean cycle
should be able to pour water and vinigar in and go through the settings and find the clean setting
1helpful
How do I clean my coffee maker? what product works best?
white vinigar and water half and half. Stinks when you do it. Sometimes have to repeat if water comes out really full of sediment.
2helpful
Machine brews very slowly. It appears plugged. Can it be cleaned?
Run vinigar & water through it several times.. Should clean it out..
then water a few times to flush
1helpful
Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
2answers
Instructions for descaling Saeco Royal Digital
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
Robert
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
