Craftsman 17765 Canister Wet/Dry Vacuum Logo
Monica Dailey Posted on Nov 08, 2013
Switch bad on shop vac how do i bypass it - Craftsman 17765 Canister Wet/Dry Vacuum
Lance Donham
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Nov 09, 2013
Lance Donham
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
5602
Points
28
Remove the switch (with unit unplugged) remove wires from switch and solider the two together
2answers
Shop vac fuse
Very rarely do vacuums have a fuse in them. You probably have a bad switch or possibly a bad motor.
Bypass power switch
You should simply purchase and install a new switch. It's not safe to bypass the switch as when you do, the entire electrical load is placed on the wall prongs when you plug in or unplug the vacuum. Depending on the brand of vacuum, you can easily order parts and replace the switch at a nominal cost.
Switch bad need to bypass switch
Monica, I highly recommend you replace the switch. By passing the safety of a switch on any appliance or tool endangers both yourself and those around you. Just to by pass the switch, you would need to disassemble the appliance. If you are going to do this then get a replacement part and replace it. :) Safety comes first , especially where mechanical and electrical devices are used.
3helpful
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
9helpful
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
23helpful
4answers
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Shop vac
Could have a bad switch, bad cord, or a problem with the motor.
May 31, 2008 • Vacuums
Top Craftsman Vacuums Experts
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
