HP 35s Scientific Calculator Logo
J
James Podolske Posted on Nov 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minus sign display problem
I seem to have hit some key sequence which makes the minus sign be upper justified vertically rather than center justified. Can you tell me how to fix this?
k24674
Level 3:
  • HP Master 8,093 Answers
  • Posted on Nov 09, 2013
k24674
HP Master
Level 3:
Answers
8093
Questions
0
Helped
4675458
Points
21596
Calculators have two similar signs: the regular minus sign for subtraction, and the negation (change sign) sign. When applied, the latter changes the sign of the quantity to which it is applied. The minus sign - for subtraction is on the central line, the negation sign is smaller and somewhat raised above the center line.
The change sign key may be marked (-) , (+/-), or +/-
My machine is giving me d minus sign
No clue because you don't tell us WHAT!
'make model (what it is)', first three words in every question please.
Face book is locked up ,what can I do?
Delete the app and reinstall it. Or, double click your menu button and all of the open apps will be displayed along the bottom of the screen, hold any one of them down until they are highlighted with a minus sign, find facebook app an touch the minus sign thn hit the menu button. This will reboot Facebook app
1helpful
HP35s minus sign display is incorrect
The minus is always centered while the negative is always at the top.
If you're in algebraic mode, press 1 - 2
You should see the centered minus sign between the one and the two. Now press ENTER, and you should see the top negative preceding a one.
The two are two different things. The first indicates subtracting one number from another. The second indicates a negative quantity.
Are you sure the minus is at the top? Or was the negative centered?
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Where is minus sign?
------------ It is the key just before the =+ key. -------------
1helpful
What do i hit to make a number an negative
Do not use the main MINUS sign for subtraction. Rather, use the change sign key. The key may have a + and - with two arrows, one pointing left the other right. On some calculators the key is marked with (-)
4helpful
Err:syntax when I try to graph with ''-'' on ti-84 plus
The calculator has two minus signs
  1. The regular MINUS sign which is used with the subtraction operation. This operation is binary, requiring two operands (two terms). In a-b, a and be are the operands (they very specific names, but I will skip this detail).
  2. The negation or change sign. This operation is called unary, requiring one operand. -a means take the negative of the number a.
These are the technicalities, in which you may not be interested. On calculators, the two operations are implemented differently, with two signs, the regular minus sign -- , and the change sign (-) usually smaller in size than the regular -- sign and raised above the main line.
Examples. Let (-) be the negation and -- the regular minus.
  • If you enter (-) 12 the TI84Plus accepts it and calculates the negative of 12.
  • If you enter 12 (-) 13 the TI protests with a syntax error
  • If you enter 12 ( (-) 13) the calculator interprets it as 12* (-13) and calculates -156.
  • If you enter --12, the calculator displays Ans--12, where Ans is the last result calculated. If Ans happens to be 0, the new result is obviously the one you are expecting. But if Ans holds a non zero value, this is incorrect.
Suppose you have to calculate X^(-2)*X^(-1/3)
You can enter it exactly as it is written above. In this case, you must use the change sign (-) in both factors.
You can also decide to use the power rules and enter the expression as X^( -2 --1/3). In this case the first minus is the negation and the second is the regular minus.
I could go on with a few more examples, but that will take us away from your present concern.
In short.
  1. If the minus sign is the leftmost (first) symbol in your function (after the Y1=) you should use the negation. Any subsequent minus should be the regular minus --
  2. If the minus sign is the first symbol in an exponent, you must use the negation. Any subsequent minus in the expression of an exponent should be the regular minus --
I hope it did not bore you death with details you do not care to know about. I do hope that it will help you prevent this type of syntax errors.
Do not forget to rate the solution
How do I ente 8x - 1 over 10 on my TI 84 plus silve edition
I am not sure what the cross (x) means: is it a multiplication or the variable x, so I took a screen capture of both cases.
The top case is obtained as follows the asterisk is the multiplication sign to thr right of digit 9; the small minus is the change sign key the minus sign in parentheses under digit 3 and to the left of ENTER key.; the forward slash is the division sign, above the multiplication sign.
This small minus called change sign makes a positive number negative and a negative number positive, hence its name. If your expression starts with a negative sign that is the one to use. Use it also for negative exponents.
As you can see the result is -.8. Notice how the - before the dot is small with respect to the regular minus, as in the last expression.
For the last expression on the screen capture, there is nothing special, except that you have two ways to enter the variable X.
1. Press [ALPHA] [STO->]
2. Press the key [X,T, Theta, n] to the right of the green [ALPHA] key.
Hope it helps.
If x is the multiplication sign
8[x] [(] (-)1
1helpful
Change sign key? +/-
It is the key with a minus sign enclosed in parentheses (-)
Hope you find it.
6helpful
I have a motorola tracfone w175g and wondering how to capitalize letters? do you have a detailed manual on the buttons?
Press "0" key.
A plus or minus sign will display in the text space.
The (upper case) "AB" or (lower case) "ab" on the top left-hand side of display will change to case you are seeking.
k24674
Grand Canyon Tech
Grand Canyon Tech
