A
Anonymous Posted on Nov 08, 2013
Pixma mx452 error 5100 - Canon Office Equipment & Supplies
Adam Gresh
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 25, 2014
Adam Gresh
Contributor
Level 1:
Answers
Questions
0
Helped
20095
Points
In my case the printer head was going all the way to the left and ending up "stuck" there. The print head could still be moved easily from left to right manually but when you turned the printer on it ended on the left side and I got the 5100 error.
I turned off the printer and disconnected the power. I took a flash light and carefully inspected the clear ribbon. In the middle there was a bit of goop on the clear "timing tape", about 1cm long. I used a clean paper towel with a bit of alcohol on it along with a rubber coated pen to keep everything away from the grease on the track and gently hold the ribbon in place while I cleaned the goop off of the tape. After that the 5100 cleared and the printer is working again.
It looks to me like the clear tape is just an indexed strip that's used to tell the print head how far it has moved. With some of the index obscured by the goop the print head thought it hadn't traveled as far as it had because it was reading fewer lines in the index. The goop was probably some grease from the track the print heads go back and forth on. Not sure how it got on the tape, but cleaning it off solved the problem for me.
I have no idea what the long term effect of ink on the plastic tape will be, but it got the printer working when I needed it and saved me from having to have it professionally repaired.
5 Related Answers
Anonymous
  • Posted on Nov 09, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Anonymous
  • 421 Answers
  • Posted on Nov 22, 2008
SOURCE: Solve error 5100.cannon pixma 145 error always out # 5100
5100 error is a carriage error. Could be caused by the carriage unit, timing strip, logic board or carriage motor. Check that nothing is obstructing the carriage from moving freely and that the clear timing strip is ok.
Anonymous
  • 412 Answers
  • Posted on Mar 09, 2009
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Anonymous
  • 119 Answers
  • Posted on Sep 21, 2009
SOURCE: canon pixma mp540 error 5100
dear,
Error 5100 points to a "carriage jam"
The carriage is the assembly that contains the printhead and cartridges.
This error can be difficult to solve because various things can cause it.
Since this is a new printer, maybe there is some packing or packing tape that is obstructing the carriage.
Verify that the carts and printhead are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've never done it before.
If this does not work, unplug, wait 3-4 min, then re-plug in. Enjoy..
Testimonial: "Really understandable answer, but unfortunatelly, it seems that my printer is dead. thx. L."
Anonymous
  • 787 Answers
  • Posted on Nov 19, 2009
SOURCE: cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
2answers
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
2answers
Canon out of ink error mx452
Press and hold STOP or RESUME button for 6 seconds.
1helpful
2answers
Error code B200 PIXMA MX452
Error B200 is a print head overheat error. Just need a new printhead. You should see the power and alarm lights flash on and off 10 times then repeat the cycle. That's confirms the fault more than the error code. Its very simple to fit a head, just be careful putting the new one in as it's easy to break the pins in the carriage. No force is needed when fitting the head. Just let it drop in and lock the lever. Try taking out the old head first and gently clean the contacts at the back as they can rarely make poor contact with the carriage pins.
Good luck
HP laptop won't display scanner
When you installed the canon drivers did you install MP Navigator? That's the program you use with the MX452 that runs the scanner. Its on the disk that comes with the printer.
What does error code 6000 mean on my pixma mx452?
Carriage error/ need to clean thoroughly. Or dirty disk film ( clock pulse) clean it as well.
1helpful
2answers
Seting up MZ452 printer
Go to the Canon website and download the printer driver. No need for a CD.
1helpful
Have mx452 cant seam to send off fax get errors
If you dial the mx452 does it indicate it is ringing. If not it does not see the phone line, if it does
try to fax to a phone you can here, does it ring? no need to answer. If not you you have a dialling out issues
4helpful
MX452 ALL IN ONE WONT SCAN CODE:5,157,69
I have a Canon MX452 All in One. I keep getting this error message, code 5,157,69, cannot scan. What can I do?
14helpful
2answers
3helpful
old marine
old marine
ZJ Limited
ZJ Limited
