Tcl tv not work led is red - Televison & Video
Posted by ahmed ali on
    Top Expert:
  • Televison & ... Master
  • 76,407 Answers
What is the model number to your TCL TV. Its SDA-SCL data line should be checked. Check all the output voltages come out from its SMPS power supply section, and make sure all of it are correct. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. In fact, its main board's system control section circuit should be troubleshooted. Check and replace the main crystal oscillator too.
Posted on Nov 09, 2013
I have tcl led m. no 24d20 only displays tcl logo and then no responce
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again. Also try bringing up the menu, and see if there's an option "factory default", and try that.
Feb 04, 2016 | Televison & Video
TCL TV Model L40P60UF; no picture and sound when switched on but stanby led is on. When power on is pressed from the remote control, the red led disappear. What could be the problem
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 08, 2015 | Televison & Video
How do i connect my Acer Aspire one D270 with TCL LED TV 40. When i connect my laptop through HDMI port screen blinks but nothing shows on LED TV .LED TV just says not supported.My laptop Graphic is I
Have you checked the settings on your TV Malik? You usually need to go to settings on there and bring up HDMI. For example, if you have TV selected on the settings, you need to change to HDMI to view stuff on your TV screen from the laptop.
Dec 10, 2014 | Acer Aspire One D270-1865
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Jan 25, 2014 | TCL 50 Class LED HDTV - 1080p, 1920 x...
TCL 21M62s TV showing standby led light on but not power on this tv
The red standby is on because the tV is not turned on. Once you turn the power ON the red led will go out and possibly another color will come on.
Oct 29, 2013 | Protron PLTV-32 Television
Won't program to our new TCL television - we have the 222 receiver
I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 14, 2011 | DISH Network IR Remote Control
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
