M
Marguerite Hart Posted on Nov 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A CD has become stuck in the CD slot and I cannot get any pieces of it free.What can I do????
The CD is a bit more than halfway into the CD slot and is stuck there. PLEASE - can you help?? I have tried several times to turn it on, but it still does not move.
castletech
Level 3:
  • Master 372 Answers
  • Posted on Nov 09, 2013
castletech
Master
Level 3:
Answers
372
Questions
0
Helped
102728
Points
1338
Press the reverese button
SD Card and disc stuck in CD slot of Alienware M14x?
try taking a small piece of wire and bending a small hook into one end slide it in on TOP of the stuck disc and hooking the center hole of the disc, (you don't want to get the wire under the disc because you could damage the disc reading hardware) also once you have the disk hooked you may have to use the tweezers to gently hold the front of the disc up to align with the slot as your pulling it out. you should feel a little resistance but don't try to force the disc out too hard.
2helpful
Cd player will not eject
Heres the method I have been using since CD's came out...
Gently slide another CD into the slot, keep hold of it! dont let it slide all the way in.
Once its about halfway in, GENTLY push down on it as you pul it back out.
The stuck CD should come sliding right out with it.
2answers
How to remove stuck CD in CD player
Is there something inside the Player preventing it from not "Ejecting"?
If there was a Mechanical Failure inside the CD Player then you are going to have to remove the Player, and mechanically disassemble the Player to (1) Remove the CD, (2) Repair the Player for future use...
23helpful
2answers
Cd's are stuck in cd player and will not eject,
i have a 2005 kia Amanti. i believe a cd is stuck and the cd palyer will not rptate or eject. does anybody have a solution?
3helpful
2answers
Paper stuck inside cd slot
There is no need to open up the console! Get someone to hold the PS3 upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from each other so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
2answers
Paper jam
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
pow-e-r-12
The 6-CD magazine will not eject from my Pioneer PD-M430 player. The 2nd-slot seems to be stuck. Is there any chance I can remedy this myself?
hello of course you can do it only you need a bit of precaution check this in magazine look for broken/deformed little piece of plastic especially in 2nd slot if it is ok next step look inside check again in the room where you put the magazine and it has a small coils check the 2nd i hope yu find the solution my best luck.........saludos
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
k24674
ADMIN Andrew
ADMIN Andrew
