The unit was dead so last night I replaced the 20A fuse and the display started blinking but none of the buttons will do anything. Also I can hear what sounds like a relay of some sort clicking on and off on the right side of the unit but I can't quite identify where it is. After a few minutes the relay quits but the display still flashes. Is there some reset button in this unit? We only use it as a microwave. FYI - The last time we used the convection oven was probably 8-10 years ago. We really love it woulld like to bring it back to life. Any assistance is greatly appreciated!!
Here is the parts page for your unit with an exploded view and parts list
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R-9H84B/0958/0123245/P0050209/00001 It is possible the switch is bad the look at part number 1-6 hope this helps.
SOURCE: Sharp Carousel Microwave oven
Assuming the unit works ok other than the display, you have a problem common to many Sharp models.
Check with www.microwavedisplay.com - lots of info on this issue and they offer a repair service for the boards at a very reasonable price.
SOURCE: Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
SOURCE: Our microwave/convection oven is about 17 years
Your membrane keypad is wearing out.
We would need the model number to give you an opinion and/or estimate.
Since FixYa is not currently
notifying us Experts when Clarification Requests are answered, you will
need to post a NEW help request.
In your new post, please
include your brand name and the full model number from the tag in or on
the unit and your symptoms.
Or you may contact me directly.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: While using microwave/convection oven in
The aluminium foil has created a short on the magnetron - the device that generates the microwaves . The magnetron failed and in turn has shorted the power source's transformer - the sizzle you hear is the secondary high tension coil burning away when the unit is powered. This of course triggers the fuse every time you try it.
There is nothing more than can be done to save this oven , the damage is too extensive. Just junk it and get a new one.
SOURCE: The display on my Sharp R-820 BK convection
The service manual will aid you in disassembly. It is here.
This can be repaired for $39.95 in most cases. Details here.
