HP deskjet 3050A j611
SOURCE: HP PSC 1210 Xi won't scan
try to locate this file from drive software disk or re-install the setup. bye
SOURCE: HP Deskjet F380 Drivers
All the drivers are here.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&submit.y=6&submit.x=4&lang=en&cc=us&y=12&x=8
Don't forget 'fixya' please!
Cheers
SOURCE: problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar.
so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer
How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a
Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in
Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
SOURCE: I can't install my hp deskjet D2360 even I downloaded my driver
I suggest Download Printer Drier directly from the website and
then try to install the Printer.
Download D2360 Printer Driver
choose the appropriate operating System
When you download the file, just remember where you save tht file.
Then Double click the file, and run setup
When you Run the Setup please make Sure that You just Put ON the Power of the Printer and no USB cable should be connected to PC from Printer
Connect the USB cable only when directed by the Setup
I hope this resolves the problem
All the best
Do rate the Solution, so we can help others accordingly
Thanks in advance
SOURCE: I need the driver to install a HP Deskjet 845c Printer.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=57556&lc=en&cc=us&dlc=en&submit.y=4&submit.x=3&lang=en&cc=us
Follow that link, select your OS, download and install the drivers you need.
Good luck
Please take a moment and rate my help for you
Nic
