When connected, the toaster is not heating enough to be used
Please make this test with the multimeter.God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord
If the oven doesn't work on its toaster and oven functions, test the main switch As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open,
test the solenoid, the switch and if necessary, the thermostat
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch (). If the oven doesn't heat, test the heating elements.
