Did you try to play games for a long time, with the stock cooler.
i'm amazed about all the gammer which are still using stockcooling and the teperature stays warm for 5 hours. And if i say they need to watercool it, just like you cpu and memory, because high temps degrease 1. the lifespan of your gear ( especially mb with cheap capacitors) enemoursly, but they overclock the graphiccard at the same time , while the effectivity decreases , caused by too warm components, they want also higher ratings from the card by overclocking. That's why i never by second hand cards or mb's or cpu's. Does the card still work; if not, does it smell burning? and did it broke, while gaming?????
SOURCE: NVIDIA GEForce 8500 GT
Should be able to find drivers here.....
http://www.gigabyte.com.tw/Support/VGA/Driver_List.aspx?ChipsetType=NVIDIA+GeForce+8500GT
You have to know the model number of you card....
SOURCE: pc games hang in the middle of the game
1st on the list drivers
2nd ram
3rd faulty video card
do a fresh intall on another hard disk and then install driver and game see if it works if it does drivers if not ram.
SOURCE: Graphics card drivers
Yes, right-click on My Computer>Properties>Hardware tab and Device Manager. Find your graphics card in the list. Click on the "+" sign to get your model. RIght click on your model. Click on update driver to make sure you have the latest driver. Also, there is a Troubleshooting tab. If that is OK, then go back to Control Panel. Click on Power Options. Set Sleep and Hibernation to how you want them.
Please rate this solution.
SOURCE: Sparkle NVIDIA GeForce 8500gt crashes comp
YOU MAYBE HAVING IRA AND DMA PROBLEMS
DO YOU HAVE WINDOWS VISTA 32 OR 64 BIT
SYSTEM.
THIS MAYBE A 3D PROBLEM, TRIPLE BUFFERING, 2D, MEMORY ERRORS AT A CERTAIN PLACE IN THE MEMORY BANK,
OR
RUNNING OUT OF MEMORY AND IT DESIDES TO RESET INSTEAD OF SHUTTING DOWN THE SYSTEM CAUSING OR START A ISSUE PROBLEM OR CONFLICKS.
MY LABTOP HAS A MOTION PITCHURE SETTING IN THE ADVANCE SETTING AREA THAT WILL SET UP GAMES UP TO THE MANUFACTURE SETTING SO YOU GET THE REAL FILLING LIKE YOU PLAY IN THE ARACADE GAMES, ONLINE LIVE SETTINGS,
IF YOU HAVE THIS OPTION AND DONT KNOW HOW TO GET TO IT CONTACT ME THREW THE WEB SITE RODGANDYSR
ROD
SOURCE: Need to update drivers for Evga e-GeForce 8500GT
Hi:
The latest and greatest drivers for your card can be downloaded at www.nvidia.com
