Samsung GT S3850 Corby II Logo
A
Anonymous Posted on Nov 08, 2013
Phone freeze corbi - Samsung GT S3850 Corby II
Paakadhe Paakadhe
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 09, 2013
Paakadhe Paakadhe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
339
Points
6
To remove freeze from Samsung S3850 use unfreeze code.You can get this code at reasonable cost from MobileUnlockSolutions.com and unfreeze it.
Note:Here,you can get this code only for European Samsung phones.
Unfreeze the corby 2
Hi, you can solve Phone Freeze on your phone model with the service on Fastgsm.com, so check it out if it would be helpful for you.
Samsung gt-s3850 phone freeze sim unavailable
I suggest you to download this applock, it has a Boost Function which may help your to be free of freezing, you can search it on Google Play and give a try!
LEO Privacy Applock Boost Hide Android Apps on Google Play
Active IMEI
You want to unfreeze it?You can get the unfreeze code for your Samsung Corby 2 GT S3850 from Prounlocking.com by specifying the country,locked network.You will receive the unlock code along with free unlock instructions.
S3850 phone freeze
You can visit Prounlocking.com and get the unfreeze code for your Samsung Corby 2 GT S3850.You need to specify the country,locked network,IMEI and get the unfreeze code along with free instructions.
Phone freeze
You'll need a freeze code which can be obtained from your carrier, bought online or at the repair shop. You won't be able to get this on your own since special hard/software is exploited to obtain codes.
2answers
My phone is freeze. how can i unfreeze this?
if you have entered the wrong pin code, you may have to contact the phone manufacturer or network provider. some phones lock for a period of time and then allow you to enter the code again. if its not a pin code issue, you could try turning the phone off and removing the battery for several minutes, to let the phone reset.
2helpful
I need a un freeze code for a samsung gt s3850 corby 2 phone on the screen it says phone freeze sim unavailable contact your service provider i have got in contact with them and it really wasnt helpful
The phone Freeze problem. Your phone has gotten hard-locked; it will not accept any unlock codes. This problem can only be caused by improper unlocking. Basically this happens if you or someone else has already entered 5 wrong unlock codes on your phone.
You can get the unfreeze code, NCK code and SPCK code from third party. After unfreeze your phone, you have to enter the NCK code to unlock and use it with any gsm network in the world. i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website
1helpful
2answers
Phone says phone freeze sim unavailable when I
If the Phone says Freeze Sim unavailable means you need to Unfreeze it,You can get the unfreeze code from here Classicunlocking.com and Unfreeze it...
3helpful
2answers
Samsung GT-S3650 phone freeze
OKAY, Ignore the posters saying that you need to buy a 'freeze code', the truth is you don't. If your phone has 'phone freeze. sim unavailiable' please enter in *2767*3655#. After you do so the phone will restart and will work with your sim inserted. I hope this solves your problem.
Kind Regards,
Tony
6helpful
2answers
For my samsung corby 3650 it says sim unavailable
try this security code, 00000000, but make sure you didn't change it before. if you typed it and the result is the same, consult the manual for phone, normally the codes are already there.,
if it doesn't give you a good result, try hard resetting your device. here's is the code *2767*3855#, but make sure to back up all your files through NPS and check if it will still ask for the 8 digits code when you insert your sim.
good luck..
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
