Question about Acer Aspire Computers & Internet
SOURCE: how to downgrade acer aspire 5720 vista to xp
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=268631&CFTOKEN=33761549
Posted on Feb 09, 2008
SOURCE: Acer Aspire 5720-6438 recovery cd/driver cd
if you need drivers, you can download it from www.acerpanam.com.
for recovery cd, i don't think acer have it online, you need to order it from them.
FYI, if you haven't delete the partition in your hdd, you can use alt+f10 to re-install your Operating system and after that, you can create your own recovery cd.
Posted on Mar 22, 2008
SOURCE: ACER Aspire 5720
Hi All,
We are a workshop in Spain & I have had several problems with "Down grading" to XP. There is essentially one problem which causes an issue with the XP installation & that is if the the BIOS has a "Fixed" sata configuration. By that I mean you cannot change it to some sort of IDE or P-ATA (Symantics). Our current problems are with an Acer 5720 & an HP Pavilion DV9700. The Acer solution is exactly as "kraken3000" had mentioned before:
1. On POST (Powerup). enter BIOS by pressing F2
2. Tab along to the second option "Main"
3. Goto last option "SATA mode" & press enter.
4. From the small selection display select "IDE mode"
5. Save & exit the BIOS. This will then set the SATA mode for XP to be recognise.
DONOT set this back to SATA Mode after you install the XP as it will NOT boot. This setting must be kept untill you "Upgrade" (If ever) to Vista. The HP is another story...
Visit the Acer Panam site & download & install the XP drivers & your good to go...
I hope that this was of help...& good luck folks
Posted on Apr 03, 2008
SOURCE: acer laptop aspire 5720 webcam
try reinstalling the driver using the CD that u got along with it.. or go to http://support.acer-euro.com/drivers/notebook/as_5720.html to download the driver. It should work after reinstalling..
Posted on Jul 11, 2009
