Virgin Mobile PCD Venture No-Contract Phone Logo
r
ravi Posted on Nov 08, 2013
Display not working only white light coming & charging indication comes on display
andel jackson
Level 1:
  • Contributor 34 Answers
  • Posted on Nov 08, 2013
andel  jackson
Contributor
Level 1:
Answers
34
Questions
Helped
8734
Points
51
3answers
2answers
I have a tough solar powered g-shock watch model wva-510a with a 2762 module. It has been put away for 3 weeks in an area where no light could get to it. The display was blank. When I exposed it to...
Hello there.
As you can see in the picture, it takes some time to charge the watch up 100%. If you are charging the watch indoors, then it will take 126 hours. The best thing to do would be leave it in sunlight for up to 6hours and the charge should come back fine.
Hope this helps.
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Mobile display problem
You need to charge it for at least 6 or 8 hours. Then unplug the charger and try turning it on.
Blank display screen
I got my display to come on while on the base unit, by making charging contacts connect. When I did this, then battery indicated it was low, then though I had taken it out a working phone. Maybe the fact is one of charging units are not charging correctly if have several. I have a 3 system unit and it is the base that seems to have the problem.
22helpful
3answers
Nokia 114 display not working
nokia white display model-144
Apr 11, 2013 • Cell Phones
I have a toshiba laptop a3056872...on a friends pc now....when i go to turn it on..all the lights come on....the page tthat says toshiba innovation....hit f2 or f12....it doesnt go any further i have a...
1. Remove the battery & switch on the PC in AC mode.
2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
4. If still no display, connect an external monitor, check if display is comming.
5. If Display is coming then your LCD is faulty and need to replace.
1helpful
Wen i conect my compuer only de power light comes on.day before i working normal and i switch off normal.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
My granddaughter has a nv52 notebook which the power on light is on but the computer does not may any sound or show anything on the screen, what can she do to get it working?
4helpful
2answers
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Top Virgin Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Virgin Cell Phone Expert? Answer questions, earn points and help others
