Run CMD.EXE as administrator
Type following commands and hit ENTER key after each command.
· DISKPART starts the DiskPart program
· LIST DISK shows numeral assigned to disks
note the numeral assigned to your usb stick
The numeral 2 will be used in this example
· SELECT DISK 2
· DETAIL DISK the info shown will confirm the correctness of your selection
· CLEAN ALL the entire usb stick will be overwritten with zeros
· CREATE PARTITION PRIMARY create a primary partition on the USB stick
· FORMAT FS=NTFS format the partition
· ACTIVE the partition can contain operating system startup files
· ASSIGN the next available letter is assigned to the USB stick
· EXIT exit from the DISKPART program
· EXIT exit from the command shell
click start all programs accessories open windows explorer
you will see your drive usually C: unless its a usb it might be another D: E: F: drive right click select properties you will see
how much used and free space you have
hope this helps
