Question about Frigidaire FEF366 Electric Kitchen Range
Clock gains time. Any way to adjust clock?
Posted by bmcreet on
Ginko
  • Frigidaire Master
  • 19,396 Answers
If the timer goes too fast you have to replace it.
Select model here to get part and diagram.
Posted on May 01, 2009
Clock keeps gaining time adjusted pendlum makes no differance
adjusting the pendulum only works if it is part of the clock mechanism
with electric clocks you adjust the time by an adjuster on the back
Nov 16, 2017 | Audio Players & Recorders
How do I adjust my mantel clock so that it doesn't gain time every day.
American mantel clocks will gain or loose 5 minutes in a week, that is considered normal. This article will help you to adjust your time using the pendulum.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
Dec 09, 2016 | Home
SET CLOCK ON JVC KD-200
Press and hold SEL (select) for more
than 2 seconds.
"DEMO," "CLOCK H," "CLOCK M," "DIMMER,"
or "AMP GAIN" appears on the display.
Set the hour.
1 Select "CLOCK H" (hour) if not shown on
the display.
2 Adjust the hour.
Set the minute.
1 Select "CLOCK M" (minute).
2 Adjust the minute
Sep 28, 2014 | JVC Car Audio & Video
How to set the clock clock gains time how to correct
You can speed up or slow down the clock by adjusting the length of the pendulum. This link will walk you through the process.
Jan 24, 2014 | Home
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
Nov 11, 2010 | JVC AM FM CD DET FACE CAR STEREO
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
“DEMO,” “CLOCK H,” “CLOCK M,” “DIMMER,”
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
display mode
• During power off:
Thanks for using Fixya
Proton
Jul 27, 2009 | JVC KD-G200 CD Player
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
Nov 26, 2017 | General Time Corporation Westclox Bell...
Frigidaire FEF366 Electric Kitchen Range Logo
384 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
