14 inch craftsman electric chainsaw
SOURCE: How interchangeable are replacement chain bars for
Your question can't be answered as aked.
If your saw requires an Intenz 14" Bar it's Oregon pns 140SDET041 or 140GPET041. Part number 140SDEA041 if not Intenz.
Plug in your requirements here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Once you get a part number it can easily be converted to other manufacturers numbers. HTH
Lou
SOURCE: while cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
SOURCE: cant get the cover back on chainsaw
The chain brake should have been released before removing the cover. You will have to release it with a large flat-blade screwdriver in the connector that runs the brake from the control handle. Hope this helps!
SOURCE: Need to know the degree to set my electric chain
A 20" bar unfortunately does not narrow it down. Fortunately both the .325 pitch chain and the 3/8 pitch chain sharpen at 25 degrees and you should have one of these chains. Hope this helps.
SOURCE: A Talon Black Hawk 14 electric chain saw AC
if the motor comes on, but no movement, then the clutch is smoked
