I have a Hisense LCD tv model f39V77c and I cannot find the part number for the LCD portion. I pulled the whole thing apart and the part number is no where to be found. Any help? I need to order a new LCD screen.
SOURCE: no physical crack,but crack like light, no picture
IF IT LOOKS LIKE A SPIDER WEB, IT'S TOAST
SOURCE: Need to order a replacement 46" LCD Screen
Sorry,not repairable,because the LCD screen panels are limited produce by the Tvs Corporations.No where u will able to buy a LCD Screen panel for the replament,but except by the tvs corporations themselves.Because it limited production of the LCD screen panels,they will sell it to u the same as a new tv.Might even cost more after the labors of by replacing the LCD screen panel.
SOURCE: need new remote
Why not phone Hisense and ask them. The phone number number should be listed in your directory and they will tell you where the Hisense outlet is to purches .. and u can ask them about a universal one
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
