1996 Dodge Ram 3500 dually. The fuse box cover is missing, so i dont know which fuse is for the brake lights. an ideas as to my next step? also my head lights are intermittant. They come on but sometimes while a am driving they go out.
For the brake lights check that no fuses are missing. Then check them all you should get a fuse tester. Go to the junk jard and get the cover if anything. For the headlights its common for moisture to get in the headlight bulb connector or harness and get corroded. Take the bulbs out and clean the connections with a wire brush or how ever you choose then put as much bulb grease as you want on the connection. This should take care it. Clean the inside of the harness too.
