SOURCE: bose acoustimas double cube speaker
Try to see the 2 ends at the speaker you have open and arrange that 2 springs and 2 metal clip to that 2 ends to reconfigure it properly...
SOURCE: Replacement speaker (upper) for Bose double Cube.
try a music specialty store or radio shack if you want to only replace the small speakers inside the cubes. If you want to replace the whole cube, there are others out there. Look on ebay and or amazon I think the brand is JA Audio. A knock off of the bose cubes that can be used as stand alone speakers without the module.
SOURCE: cube speakers w/ no subwoofer
I have the acoustimas systrem and the speakers do need the sb. That's the heart of the system.
I dropped my two front cubes and neither work. If you would be willing to sell yours at a reasonable price I would be willing to buy.
Please contact Bose customer support and I believe they will tell yiou the same thing.
Please let me know.
SOURCE: Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
SOURCE: free booklet/part #149393
How do I connect my bose 901 to a Rotel RC 1070 pre amp and the Rotel RS1090 main amp?
