Question about Lutron DV-600P Diva Single-pole 600 Watts DV600P White
Lutron diva dimmer has time delay when turning light on
ken skalski
    New Friend:
  • 152 Answers
If it's turning on led s, that's nirnal
Posted on Sep 02, 2016
5 Related Answers
mpservices
  • 191 Answers
SOURCE: humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Posted on Nov 23, 2008
Anonymous
  • 15 Answers
SOURCE: Dimmer switch is not dimming
florecent bulbs wont dim unless they are dimmable.
Posted on Dec 25, 2008
Anonymous
  • 1605 Answers
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Posted on Mar 30, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Posted on Aug 19, 2009
Testimonial: "I appreciate your help."
VtToolMan
Mark
  • 704 Answers
SOURCE: LUTRON DIMMER
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
Posted on Sep 10, 2009
Our lutron dimmer switch only has a yellow light and no green light. It obviously will not turn on any of the lights it is connected too. We have flipped all the breakers and everything is good. All the...
I would call their tech support center for clarification, because what you descirbe doesn't immediately make sense. The only light that a Diva has should be a yellow glow through the back of the plastic. If you're talking about a green light, then maybe you mean a Maestro, but there's no yellow light on a Maestro... it's making me think you may have a different manufacturer.
Regardless, call tech support to figure it out. They're at 1-800-523-9466 and available 24/7.
Dec 15, 2010 | Lutron Diva Dv-600P Light Control By
The slide on the diva does not dim anymore - what happened?
Sometimes a hellacious lamp blow-out or lighting strike can knock out the dimming element in the device. Call their tech support line at 1-800-523-9466. You may want to suggest that they upgrade you to a 1000-Watt dimmer so that the issue doesn't happen again.
Dec 08, 2010 | Lutron Diva Dv-600P Light Control By
How do you remove the existing wires from the DIVA-600P light control. They are not screwed in, rather they are pushed into the back of the dimmer
You have 'quick connects'
Next to hole where wire goes in, is slot for small screwdriver.
Push screwdriver in real firm while pulling wire.
Nov 12, 2010 | Lutron Diva Dv-600P Light Control By
Night light in lutron wall switch flashing can it be fixed and how
Unfortunately, no. Its a neon bulb that gets soldered into the product, so its not something that can be tweaked or replaced. My suggestion would be to call their tech support number 1-800-523-9466, and see if you can get them to replace the whole dimmer.
Nov 10, 2010 | Lutron Almond - Diva Incandescent Dimmer...
I need to install a diva low voltage electronic dimmer. An incandesent dimmer was previously installed. lights flickered. There are 4 wires on the dimmer. (green black whate and yellow) I know what to do...
The dimmer connections should go like this.
Black from dimmer to black Constant Power In Wall
White from dimmer to Neutral (Whites) in wall
Yellow from dimmer to wire out to light (usually black)
Green from dimmer to BARE GROUND WIRE
May 08, 2010 | Lutron Diva Electronic Low Voltage 3-Way...
Lutron skylark s-10p 1000w dimmer. why is one
This video from the Lutron site shows the Diva switch but it is the video for the Skylark single pole switch also. It makes no mention of one wire being a larger gauge and does not differentiate which wire connects to line power and which to load. I do not think the wire gauge makes any difference.
Aug 11, 2009 | Lutron 1000-Watt Incandescent Dimmer...
Mar 30, 2009 | Lutron Electronics Diva 3-Way Duo Dimmers,...
Lutron DV-600P Diva Single-pole 600 Watts DV600P White Logo
275 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
mpservices
Vernon Taylor
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
