Question about Coby MPC895 MP3 Player
My coby mp3 player will not turn on
When its plugged ito the usb on the computer there will be someting on the screen if u unplug it and try to turn it on it wont mpc7095 will turn on while plugged in to computer put will not when unplugged
Posted by m-o--o on
  • Anonymous May 09, 2009
    batteries lol
Anonymous
    Scholar:
  • 71 Answers
These just use AAA batteries. Have you tried replacing?
Posted on May 01, 2009
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
I just got my Coby Mp3, and i plugged the USB into my computer and the autoplay screen that is supposed to come on my computer, hasnt.
Does you computer detect a new device when you plugged the Coby MP3 player?
If Coby MP3 player has cd driver, better to install it to your pc. Some computer/laptop doesn't detect autoplay when new USB device plug-in
May 07, 2011 | Coby MP828 MP3 Player
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Hello
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 10, 2010 | Coby MP-610 MP3 Player
Every time i try to turn mp3 on the screen only says coby the main screen wont show the music icon or let me do anything else
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again.You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Here are the steps:
  9. After the firmware update is complete, you will receive a checkmark in the Firmware box.
I hope that helps.
Dec 27, 2009 | Coby MP-610 MP3 Player
Help!!! computer won't recognize my new Coby 4GB mp3 to sync
ok you need to unplug the mp3 from usb port and then shutdown your computer properly then wen it is totally shut down turn it off at the wall and then back on the same thing happens with me you properbly just didnt shut your comp down properly last time you used it
May 06, 2009 | Coby MP-610 MP3 Player
How do I charge my Coby Mp3 player MPC885?
Takes about 3 to 4 hours to fully charge if you have a USB 2.0 port.
Feb 03, 2009 | Coby MPC895 MP3 Player
from what i have been experiencing, the coby will shut off when unplugged from your computer. Hold the power button for at least 20 seconds and it will turn on.
Dec 26, 2008 | Coby MP300 MP3 Player
HELP ME PLEASE!!
I'm not sure which Coby I have but my computer wouldn't read it when I plugged it into the USB port. What worked for me was to take out the battery, plug it into the USB port, add a couple of mp3 songs, unplug it and plug it back in. It was recognized with all the existing media on it and I could edit and delete. Hopefully you have room to add an mp3 or two. My solution last time it happened was to reformat and reload.
Aug 08, 2008 | Coby MP-C827 MP3 Player
Coby MP-C7095 Won't turn on
On my Colby player there is a small reset hole in the back. Mine has sometimes just stopped playing and shuts off. If you use a small wire (paperclip works well) push it in and reset it.
Mar 12, 2008 | Coby MP-C7085 MP3 Player
Coby MPC895 MP3 Player Logo
210 people viewed this question
Top Coby Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
