Woke up this morning and noticed that the sound on my tv is muffled (like talking to a person on the telephone on a windy day). Didn't notice it before today/last night when I watched it. Normally don't have the volume on too high (10-12). The muffling seems to be getting worse as the day goes on. Tried resetting it, but still no change.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
SOURCE: Muffled faint sound and flickering screen on Insignia NS-32LCD
you have defective filter capacitors!
SOURCE: New Samsung Tv High pitched hum
Don't know if people are still having this issue or not but figured I'd post what i went through to help anyone that has. My LN-T3253H tv as out of warranty when I finally got around to calling Samsung. They flat out lied about the commonality of this problem and I convinced them to at least pay for any parts. Problem is the labor of a technician would be around $150. So, I bought the new power supply from Partstore.com for around $70. Just go to partstore.com and enter your model number and look for the power supply on the page. It took 3 days to get the part. It was very easy to replace. All you have to do take off the back cover of the tv (think there were around 12 screws all around the outside and one where the A/V connections are and pull off. Unhook the plugs going to the power supply and the four screws holding the board and then replace with the new board. So far, this fixed the issue. Keep your old board in case it starts happening again. You can probably have the old board repaired to fix the original problem since so many TV repair shops are aware of the issue. I am trying to find out from someone which specific capacitor or other piece is causing the issue and plan on fixing it myself. If and when I do, I will also post that.
Make sure you give Samsung a ton of grief when you speak to them and see if they lie to you also. I had just bought two of the new Samsung LED TV's for my media room. They work great but I returned both because of Samsung's refusal to fix my LN-T3253H and I will never, ever buy Samsung products again.
SOURCE: I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
SOURCE: The volume on the TV doesn't work. TV worked fine last night
You can always turn your TV off, unplug it from the electrical outlet, wait for 30 seconds or so, plug it back in, then turn it back on. If you have kids check the menu options to see if they may have tampered with it unintentionally. If all else fails, call Vizio and ask for their professional help. If you are not satisfied with their help and assistance, make a complaint by going to BBB.org (Better Business Bureau). Maybe if you tell Vizio that you're going to call the BBB then they might take you a little more seriously.
SOURCE: 37MF321D/37 TV turned off last night. This morn, won't turn on
Please read these replies to the same problem. A new power board costs around $284.00..
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
Device phone was least manufacturer over impress user voice telecommunication however available means to improve impressions attained at alternate receiver device are discussable. First the telephone captures voice as delicate as is produce able. Attempt to produce voice with an impressive pronouncement to human voice to capture request expectation at alternate locate devices. Second, telephone voice is captured from an alternate device that has methods of improving audibility. For example, establishing telephone speaker devices that output audio makes imprssionful expectations, Also, computers that are attached telephony device has the capacity to capture displays to improve sound audio effects. Alternately, acquiring from retails telephones that have an improve voice functionality resolving audibility request. The telephone manufacturer makes innovativeness features as notice cancelling at backgrounds during telecommunication also among feature to regulate the volume feature to capture loud or reduced user expectations.
