SOURCE: I can't unscrew the bolts on my Kohler 3386 rialto
There is clips where the bolts should be .Flip the clips up grab hold of the seat and pull it strait out towards the front of the toilet.
SOURCE: Get seat of Kohler K-3386
Roberta3fan could be giving bad advice based on experience with other toilets. This does not seem to be an option for this toilet design. I am in a similar situation and it appears that the nut (and it is a metal bolt) is not what you would expect. Here is a picture of the anchor kit for this toilet seat: http://www.plumbingsupply.com/images/kohler-anchorkit-84999.jpg I am going to assume that the sleave that should be engaging the bolt is cross threaded and try to grab it with a pair of vice grips. I'll let you know if it works.
SOURCE: How do we replace the seat on a Kohler K-3386-0
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
