SOURCE: can't connect to linksys wireless router
It's the particular type of security you've got set up. Some formats of security require the key to be between a minimum and maximum number of characters, some require it to be a set number of characters. If you have problems, reset the router using the reset button on the back, and run the setup again.
SOURCE: SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
