Question about Radio Shack IndoorOutdoor Thermometer with Hygrometer
6300772 will not register indoor temp
Will not register indoor temp
I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Apr 01, 2018 | Measuring Tools & Sensors
I have an older model springfield precise outdoor temp not registering on indoor unit. Batteries have been changed, reset button pushed. Model #EMR899. Cable free
Steve, thanks for that info on the reset button , I go through this every time I change batteries. I put a note on the back of my Springfield temp now.
Jan 20, 2018 | Springfield Measuring Tools & Sensors
What is the low pressure for a 410a 3 1/2 York when is 90temp at fh outside.
The outside ambient temp has little effect on the suction pressure. The indoor temp is what will slightly effect the suction pressure. In the trade we say we want a 40 degree evap coil, this means approximately 125psi. This is when the indoor temp is around 74 to 78 degrees. The hotter the house, the higher the pressure. I like to see a 50 degree evaporator when the indoor temp is above 80. Charging by subcooling is the way to go!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 21, 2017 | Heating & Cooling
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
How do i change the indoor temp. sensor for the esa3125-L
Indoor temp sensor will be located right behind the grill, easy to do just do like for like when you remove old one
Sep 01, 2011 | Haier ESA3125 Wall/Window Air Conditioner
ERROR CODE E1
Indoor room temp sensor defective replace it.
Jun 10, 2010 | Haier ESA3125 Wall/Window Air Conditioner
Carrier Model No 42NVQ007MM inv, NO Heat output
unit should be locked out on low temp and your electric heat should be running. is your installer a service tech or just an installer that could also be the problem if he is a service tech it would work correct when he left
Jan 31, 2009 | Carrier Heating & Cooling
Radio Shack IndoorOutdoor Thermometer with Hygrometer Logo
61 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
