Harley Davidson Road Tech HA90 MP3 Player Logo
Posted on Jul 27, 2017
Road tech ha90 back ground noise
I installed a road tech ha90 mp3 player on my 2004 harley ultra classic. i worked and sounded great untill i started engine. you could then here a back ground wiening noise thtat would go up and down with the engine rpm's. i tried installig a nosie supressor on the ground and still same thing. radio, cd and all still work great. any ideas. (tried changing the a & b switch just made music and noise louder) jim
2 Related Answers
Anonymous
  • Posted on Jul 24, 2008
SOURCE: Road Tech? HA90 MP3/WMA? Digital Music Player
My husband hooked one up with Kuryakyn speakers (amplified). BUT - we CANNOT get the music on the card...Windows seems to not like the idea of synch-ing without folders and the MP3 player cannot read folders... I'm pulling my hair out over this!!!!
Anonymous
  • Posted on Nov 19, 2008
SOURCE: Harley Davidson Road Tech HA90 MP3 player
You can go to www.signsbykines and find the complete instructions for the Harley HA90 MP3 player
tip
Harley davidson 1550
my Harley Davidson has a 1550 big bore kit and now it popping and back firing when you try to feed gas to motor and sounds like a knock in the motor
Harley davidson sc card player ha90
You could also try a noice reducing spark plug.
Are there any upgrades for the Harley Davidson Road Tech HA90?
Not really, The problem with the older radio is that the way they fed the power to the mp3 side was to back door it through the FM modulator, thus resulting in a lower volume than theradio. Unfortunately there is no fix for it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Trans noise
hey you didnt say the year when you say it whines the noise is from gear engagement lash (gap) you probaly have 10-50 or 20-50 oil in it to get it quiet put GL70-GL90 (gear lube 90 is easer to find and works great they harley used to use it in older bikes now they try to use the same oil 20-50 in everything engine, trans ,primary, hope this helps
1helpful
1998 ultra classic
check brake switch by rear master cylinder
Either the switch is bad or the wire came off
Cruise quit. brakelight stays on! on 1998 ultra classic
This is going to be a problem with one of the brake switches, most likely the switch on the front brake lever. The switch generally has slipped out a bit and needs readjusting, or corroded slightly on the inside and needs cleaned and lubed. What's happening is the brake switch is on, as if the brakes were applied, and the cruise's automatic disengage function when the brakes are applied is kicking in and not allowing the cruise to work.
HA90 MP3 Player Display
Will only show the number of the song
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
