My 18v lxt wont work ln low gear
I KNOW IT !!! MAKITA the first gear is damaged the notches in the gearbox (planet-transmission)are grinded away about 2 or 3 mm are left and the gear shaft will not fit in the notches anymore , MAKITA the BDF 4** and many more models have all the same gear box problem, (NOT EVERY MODEL of MAKITA but much models ) LXT 18V and ??? because of the planet transmission GEAR BOX they are oft very vulnerable to switch over from one to 2 or from 2 to gear 1 the gearbox should anyway be replaced , and switch the topswitch on top of the machine without use the power switch at the same time its must standstill allways when shifting 1 to 2 or vice versa, inside the top switch there are special 2 springs build in inside to switch without turning because its have nothing to do with a synchronic gear box of a car , or choice to prevalence of repetition if you will not have again this trouble again buy Panasonic or Festool powertools this if you have people who are working with your tools you should never have problems with gearboxes anymore because of that notorious MAKITA problem by much models of Makita BDF4** and may be more models is also proven that have i so much this problem seen and repaired . but the gearbox itself from MAKITA is also not so expensive in compare to other powertools. but other tools moastly are selling individual parts like gearshafts and have metal notches instead of cheap plastic and not separate to buy, Makita delivered only 1 complete gearbox because its cheaper to get and all of the parts are new . marketing technical choice of MAKITA.
