My panasonic CN-HDS620D indash TV DVD when playing DVD does not have onscreen viewing i tryed to bypass it but it does not have a parking break wire what can i do
My panasonic CN-HDS620D has no onscreen viewing when am playing a DVD but i cloud hear what's playing on the DVD,it also does not have a parking break wire,i tried to bypass it but was unsuccessful.what should i do
It seems like you're encountering some issues with your Panasonic Strada CN-HDS620D car radio/DVD player. The freezing and button unresponsiveness, along with the language being set to Japanese, can be frustrating. Here are a few steps you can try to troubleshoot the problem:
1. Reset the device: Look for a small reset button on the front panel or the side of the device. You can use a small pin or paperclip to press and hold the reset button for a few seconds. This will reset the device to its factory settings. Note that this will erase any customized settings or saved data.
2. Check the disc: Make sure the DVD disc you are using is clean and free from scratches or dirt. A damaged or dirty disc can cause playback issues. Try cleaning the disc gently with a soft, lint-free cloth and insert it again to see if the freezing issue persists.
3. Check the power supply: Ensure that the car radio/DVD player is receiving a stable power supply. Check the wiring and connections to make sure they are secure and not loose. If the power supply is unstable, it can cause the device to freeze or malfunction.
4. Language settings: If the device is set to Japanese and you're not familiar with the language, you can try changing the language settings. Look for an "Options" or "Settings" menu on the device's display. Navigate through the menus to find the language settings and change it to your preferred language.
If the above steps don't resolve the issue, it's recommended to consult the user manual for specific troubleshooting steps or contact Panasonic customer support for further assistance. They may be able to provide additional guidance or recommend a professional service center if needed.
I hope these suggestions help you resolve the freezing and language issue with your Panasonic Strada CN-HDS620D car radio/DVD player. Let me know if you have any further questions or need more assistance!
Indash DVD units are programmed not to allow DVD's to play while the car is in motion. The unit only allows DVD viewing when the car is parked and the parking brake activated.
To get around this, you simply splice the parking break wire from the radio to the -NEG wire of the radio.
It's not that difficult. Get a two position toggle switch and run the wire that normally goes to the brake, into one end of the toggle. Then run a wire from the other end of the toggle to a ground. Whenever the message comes up on the screen about viewing while driving, flip the toggle switch on then off and it will bypass the safety feature. That's how I did mine and two other buddies of mine.
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
