really, ALL? use the quickest and simplest way is: remove all partitions on your HD then create a new ones with different sizes. But, if you're concerned with the content and want data to get completely wiped out then there're different procedures (depending on the level of your concerns).
want to down load firmware to get free download games,and music,etc, for my psp portable plz give me the quickist way to get started wif out having to sign up, want to play movies and games asap ,thank with every think a psp ment to do
Sounds like either the drive was disconnected while running or may be having problems. CHKDSK automatically shows up if windows senses formatting or media problems. The fact that it did not complete tends to be indicative or hardware failure. Although the Freeagents are good as a series any drive can fail without warning.
If you go to www.seagate.com and download SeaTools it will allow you to test the hardware of the drive. try the S.M.A.R.T. check first as it's the quickest test and will spot most early drive failure with ease.
If the drive passes the smart test try the short generic, then the long generic. If any of them fail you likely have a dead/dying drive and will need professional help recovering your files, a service I perform as a part of my everyday job. If it passes them all then the problem is logical and although you can ask a pro to fix it you can download some inexpensive software that will get you files back(on a different drive) the simply use the freeagent software to reformat the unit and continue using it normally.
If you have forgottan the code you will need to get the phone flashed this will reset the code back to the defult of 0000 this is the quickist solution
