Question about Pride Mobility Products Health & Beauty
Why does my pride colt xl8 beep?
My scooter makes a constant beeping sound, is this a battery problem?
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: The scooter will just start beeping 7 times and then won't go.
Call pride. That is under warranty. The will replace it.
Posted on Apr 06, 2009
Anonymous
  • 40 Answers
SOURCE: Pride "Celebrity XL Deluxe" 4-wheeled Mobiltiy Scooter
Sounds like your motor brake is out. Usually the discolor on the brake indicates it has overheated.
Posted on Apr 12, 2009
oregoon
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: how do i remove the pride legend classic xl8 seat
hi, be careful here as it can make your back ache,
now there is a lever to the right of the seat, pull it up towards you and
turn your seat 90 anticlockwise, so the seats not facing the control panel, at right angles, you should now be able to lift the seat , take great care here if you have back problems in the past as some seats are quite heavy.
Regards
GeWiz.
Posted on Dec 13, 2009
Testimonial: "thanks"
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: I HAVE A PRIDE 3
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Posted on Jan 20, 2011
HUSBAND FLIPPED HIS PRIDE CELEBRITY X SCOOTER STOOD IT STRAIT UP IN THE AIR.NOW NOT WORKING.5 FLASHES
Five beeps? Maybe it's not the same as my Celebrity XL8 but my instruction manual talks of a 1+4 beep warning meaning low battery charge. It also suggests checking that the wiring harness connectors are all fully connected - that would include the battery terminals of course. If your hubby managed to do a wheelie this sounds a strong possibility if the batteries were dislodged. Anyway, I attach the page from my Celebrity XL8 manual, you can find other Celebrity manuals online. My congratulations to your husband, I've yet to master wheelies!
Jun 13, 2017 | Pride Health & Beauty
Go Go Ultra X Scooter is randomly beeping while in use. The scooter seems to be working fine, so I don't think beep codes would apply. It just beeps 1-4 times at random while we are using it.
Pride Mobility Products Sounds like the motor is getting too hot. Several reasons for that. The brushes in the motor can be worn, too much weight on the scooter, rider + whats in the basket or is being carried by the scooter. Rough terrain, grade too much. Never ignore the beeps. They tell you the health of the scooters systems.
Sep 09, 2016 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
How easy is it to change the brake lever and hydraulic reservior on a Pride Colt xl8
The brake lever IS the hydraulic reservoir. I wouldn't want to try replacing it since it requires a lot of dissembling of other components to get to the lever and brake lines.
Aug 11, 2016 | Pride Health & Beauty
Hi, i have a pride colt xl8, it makes a continuous beep when switched on, status led is fine , not flashing to show a fault, how can i stop this beep?
Make sure the disengage lever is in the correct position. If it is, then the position switch on the lever is bad.
Jul 22, 2016 | Pride Health & Beauty
Pride Celebrity XL8 - problem with right side indicators
hi Stuart, have you check out the actually switch that you pressed to activate the indicators ?
Regards
Rob
Apr 18, 2016 | Pride Health & Beauty
My Pride colt XL8 mobility scooter has solid tyres can I convert them to pneumatic tyres
Hi yes think you can but you will need to replace all wheels and tyres
Mar 28, 2015 | Pride Health & Beauty
Legend classic x18 measurements
hi, can you explain in more detail what information you require ?
The XL8 is one of the best 8mph mobility scooters out there, sadly it been replaced by the Pride colt brand..
Regards
Jan 21, 2013 | Pride New Mobility Legend 4 Wheel Scooter
Colt xl8 code 7 fault changed speed pot still cuts out
hi, can i ask you what the pot was like , a electronic one or mechanical one ?
If it's Electronic check there is a 24v - + plus voltage on the red and black cable. This is a common problem with these scooters.
regards
www.gewizrepairs.co.uk
Jan 07, 2013 | Pride Mobility Products Pride Legend XL -...
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Oct 19, 2009 | Pride Mobility Products Pride Legend XL -...
Health & Beauty Logo
24 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
