I JUST REPLACED A BURNED OUT PC BOARD AND RAN THE UNIT FOR ABOUT 10 HOURS AND THE POWER SHUT DOWN.
I CHECKED THE PC BOARD AND THE CAPACITOR MELTED AGAIN.
CAN YOU TELL ME WHAT WOULD CAUSE THIS?
I PUT DIELECTRIC GREASE ON ALL THE CONNECTION AND CHECKED THE GROUNDS. NO I HAVE TO RUN IT FOR 10 HOURS. THANK YOU FOR YOUR HELP.I PUT DIELECTRIC GREASE ON ALL THE CONNECTION AND CHECKED THE GROUNDS. NO I HAVE TO RUN IT FOR 10 HOURS. THANK YOU FOR YOUR HELP.
AnonymousMay 18, 2009
no spark
no spark
You can't post conmments that contain an email address.
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
some generators honda springs to mind have a thermal cutout usually connected to the on / off switch wiring for the ignition they usually come in the form of a little bolt on part. trace the wiring and see what you can find.
beware though your machine could be overheating and the cut out working correctly.
make sure that the cooling fan on the engine is ok there are no blockages / restrictions and is your machine in a suitable place to get plenty of cool air ?
the usual reason is a stuck float in your carburator , can be caused by dirt/rust etc , remove carb bowl and clean , there is also a very small needle valve which is attached to this float ( metering needle ) these can leak. if all else fails always turn off the fuel supply to the generator whilst not in use
Nearly all of the Powermates have the same 5 gallon fuel tank. I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
no spark
