Wiring hk12x2
Hello jose08042008,
Your sub has dual 2ohm voice coils and can be wired to present a final load to the amplifier of either 1ohm or 4ohms. Unless you have an amp that is stable at 1ohm (not many are), then you will want to use the 4ohm wiring. To wire for 4ohms, jumper the positive terminal of one voice coil to the negative of the other terminal, and connect the remaining positive and negative terminals to your amp. If you know for SURE that your amp is stable at 1ohm, you can connect both positives and both negatives together on the sub and then to the amp. But if the amp 1ohm stable, this will result in overheating, and/or going into "protection" mode, and/or damage to the amp.
Hope this helps.
