Phone is not modded in any way or rooted. My HTC Inspire was on the lock screen and when I unlocked it the screen froze before going to home screen and just shutoff and never came back on. I tried the Ubuntu fix for qhsusb_dload it didnt work. Please help me I like the phone to be alive and not a brick. I didnt do anything with the inspire to cause the issue it just happened randomly.
SOURCE: I just purchased a new HTC Inspire 4G cell phone
Thanks for visiting FixYa!
Just a note:
HTC Sync cannot be used for file transfers of music and videos.
To do that, you need to remove your phone's memory card - insert it in a PC - download the Music/Videos to the PC - then transfer them to the memory card.
SOURCE: my phone turned off randomly
First of all change your battery and try again if nothing happens don't do anything just go to service centre with a photocopy of purchasing bill.
SOURCE: MY SIM CARD WONT WORK IN MY HTC INSPIRE
switch off your mobile and keep away your sim, insert another working sim in the mobile and turn-on your mobile... if this sim is working, then turn off your mobile and re-insert your old sim. now it will work.
in case mobile is not working with new sim, you have to replace the "signal chip" of your mobile.
Best of Luck!
Pawan Verma
SOURCE: my htc inspire won't turn on what do i do ?
Make Sure if Your Baterai if Fully Charge.
Because if the baterai Over Low,when you charging it will need 5 to 15 minute to show Charging indicator Progess Bar.
And if the baterai over low,Cellphone will only Show Black or White screen in a couple second when turn On and then off automaticly.
SOURCE: Htc inspire 4g stuck on lock screen and won't unlock
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding. First, try this: If that doesn't work, or if your phone is frozen: All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
