These menu keeps popping up on their own i'v tried a few things but nothing works plese help this is so annoying especially when i'am studying because when it pops up it takes a while to go away
I have a Dell E171FPB monitor that had the
same problem with the Main Menu coming up and I thought I would tell you
what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and
slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back
cover.
At the bottom of the monitor case, there is a small circuit board the
holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second
switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence
while holding the switch with a pair of needle nose pliers. I had to
rotate this process from one prong to the other while all the time
applying slight pulling pressure on the switch pulling it away from the
circuit board.
8. Once the switch was removed, I put the cover back on and tightened
up the five screws.
9. Then I slid the base back in the slot it came from and tightened the
four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so
very happy.
Posted on May 30, 2008
Sounds like a button is sticking. Does it seem too sensitive? It should give a little resistance when pressed and have about 0.1" of travel. Try gently prying outward on the offending button with a pin or needle. If you're comfortable taking the monitor apart, do so and check the alignment of the menu buttons.
Posted on Oct 05, 2007
i have a 52 inch hdtv by RCA. the main menu keeps on popping up, then it goes away or i have to press clear. i know the button is not sensitive or sticking, can someone please help.
the monitor screen automatically pop up menu then i fixed it the problem is the sub-menu automatically adjusted and i can't find how to open the factory sub menu
