Question about Smeg F170 Pyrolytic Stainless Steel Electric Single Oven
Timer "bell"constantly ringing on my fisher and paykel thyme oven
Turned oven back on at wall switch adusted clock and now timer bell constantly rings
1 Related Answer
Anonymous
SOURCE: FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Posted on Sep 14, 2007
Only numbers I can read on Fisher and Paykel Freestanding Multifunction oven to set clock after power outage are 87042 RA61OMEW34
to be honest you should always turn it off at the wall when not in use for safety reasons most common one is to press the two far left buttons and the second to last button all at the same time
How do you stop the ticking on a fisher and paykel classic oven
theticking is common all all their analogue clocks so turn it off at the wall switch when not in use
1helpful
How do you start the clock on Fisher & Paykel
Fisher and Paykel does not know that model number. Could you recheck it please and advise us?
Hi, I have a Fisher and Paykel Thyme Stove and the two big elements wont turn down, Whats wrong and can it be fixed cheap?
this is a common problem ,the switchs that turn on the elements are called thermostats,and they are faulty, an easy repair by any electrican
The timer switch was mistakenly turned on and has shut the oven off. We can't make it go. How do you override to get it back to manual mode
Hi there, it depends what kind of oven you have. Most Fisher and Paykel ovens for example have a pair of small knobs under the clock. You would need to turn the left one to display a little picture of a hand to turn it back to manual. But just about every oven is different and have different ways of selecting manual/automatic mode. Hope this helps at all.
Jul 08, 2011 • Ovens
1helpful
Hi.. I have a wall oven fisher & paykel model 600e and after my girlfriend tried to use it pressing all the buttons without knowing what she was doing the element is not heating up anymore :( what...
The electronic timer must be in manual mode for the oven to work. Turn the oven on. Play around with the clock/timer buttons using as many combinations as you can. When the oven indicator light comes on the clock/timer is in manual mode. This could take 5 minutes or more. Be patient.
Mar 01, 2011 • Ovens
1helpful
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Can't turn off ring on oven timer. Ding ding driving us mad
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Smeg F170 Pyrolytic Stainless Steel Electric Single Oven Logo
Top Smeg Ovens Experts
Paul Bade
Dennis Boxerman
Are you a Smeg Oven Expert? Answer questions, earn points and help others
