First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
U can't hook the satelite signal to the PLaystation 2.The satelite hook up to the main in the Antana input.The playstation 2 must use the RCA cable came with the Playstation 2 hook up in any Audio,Video in put in the the tv.Tune in what input u hook up like 1,2,3,extra..use ur Playstation 2.
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
So you want to connect your red and white cables from your satelite box output to the receiver's auxillary inputs or TV inputs.
OR
Red and White from your satelite output to an input on your TV, then another red and white from an output on your TV to the recevier. This way you can have sound from the TV and use the receiver when you want things to get louder. You also need a yellow single connector from the satelite to the TV to carry video. If you are using a coax cable from your satelite to your TV then you are cheaping yourself out of picture quality.
This could be an unshielded cable problem. Also magnetisam from speaker(s)(i.e. subwoofer) could affect signal from satelite antenna, or could affect satelite receiver if it's near.
