Car Audio & Video Logo
Question about Car Audio & Video
CORRECT CONNECTION TO AMP BEING A FOUR TERMINAL SPEAKER
I wish to connect a pair of KICKER SOLO-BARIC subwoofers but as they are a four terminal speaker what is the correct way to connect these subs to a four channel amp?
Posted by i_starling on
Anonymous
  • 655 Answers
Hello i_starling,
The Kicker L7's come in either 2ohm or 4ohm dual voice coil (DVC) versions.
Whatever amp they are connected to, you need to know both the impedance of your L7's and the impedance of your amp. The L7's dual voice coils can be wired to provide a total of four different loads:
2ohm coils in parallel = 1ohm load
2ohm coils in series = 4ohm load
4ohm coils in parallel = 2ohm load
4ohm coils in series = 8ohm load
Your best connection would be the one that results in a final impedance load that is supported by the amp.
Hope this helps.
Posted on May 01, 2009
1helpful
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
2helpful
3answers
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Como conecto 3 bocinas l5 de un cajon a un amplificador
Firstly, lay all 3 speakers face down next to each other. Note the connections +- +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the center speaker(+). Take the center speaker (-) and connect to last speaker (+). The last terminal(-) will go to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
Why did one of my speakers stop playing i have 2 solo baric l7. i dnt think it's the speaker but i dnt know what it is help help help sos
Check the speaker fuse (inside Pwr Amp), try to connect to the other channel of the Power Amp, check RCA cable from source( Player) connection. There could be one channel of the power amp defected too
How do i wire a solar baric l5 to a planet audio 999w amp?
You should bridge your speaker on the amplifier. Check your connections on your amp. Normally it will be the - (Minus) on the left channel and the + (positive) on the right channel
3helpful
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
2helpful
I have 2 kicker l7's 4ohm, how do i wire them down to 2ohm?
If the subs are dual 2 ohm voice coils.....
  1. For a each sub, connect one of the "+" terminals on the sub to one of the "-" terminals. This makes each sub 4 ohms.
  2. Connect the unused "+" terminals of each sub together. Do the same with the unused "-" sub terminals. This makes the sub combination 2 ohms.
  3. Then connect the "+" and "-" sub terminals from the above step to the amp.
If the subs are dual 4 ohm voice coils, you can't connect both subs in any fashion to get a 2 ohm impedance. The best you can do is make a single sub 2 ohms by connecting both "+" terminals together and both "-" terminals together or the pair of subs 4 ohms by doing the same, then connecting one sub's "+" terminals to the other sub's "-" terminals, then connecting the other "+" and "-" terminals to the amp.
Kicker L5 solo baric
Wire the speaker in series and bridge the amp
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
