Question about Lifesmart Renew Infrared Quartz Heater LS1500-4 1500W LS-HPTC15PB
Looking for the manual for lifesmart Renew infrared Quartz heater LS1500-4 1500W LS-HPTC15PB
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
Mar 04, 2016 | Duraflame Powerheat 1500W Infrared Quartz...
What causes it to shut off?
I found nothing... iHeater 1500 Advanced...
(MY fault: strongly suggest the TELEPHONE)
Try
officialiheater.com
http://officialiheater.com/
or follow contact instructions (below)
Please be sure to read and follow all of the service
procedures outlined in this owner's manual. If you have
any questions concerning your iHeater, contact the
iHeater Customer Service Department at 1-800-469-0456
1-800-469-0456
iHeater, LLC.
5789 Park Plaza Court, Indianapolis, IN 46220
www.officialiheater.com
Carnac the Magnificent
Jan 02, 2016 | IHeater 1500 Advanced Infrared Heater...
I have a I heater that will not turn on. Last time it worked fine. What should I check ?
first check the outlet its plugged into to be sure there is actually power there, if not check your breaker box, it may have overloaded the circuit and popped the breaker. if all good there, check the unit for a fuse, which may be blown.
Oct 11, 2014 | IHeater 1500 Advanced Infrared Heater...
Heater Shuts Off after 2-3 minutes
Does it matter if the thermostat is 120v or 250v?
Jan 31, 2014 | Lifesmart Renew Infrared Quartz Heater...
My iHeater shuts off
Our heater cuts off after 2 mins or less and it shoe 90 on the temps diplay. Had it for a couple of years. It's been vacuum and clean and still the same results. I don't have the schematic or the owners manual..
Jan 17, 2014 | IHeater 1500 Advanced Infrared Heater...
Heater runs 1 cycle then turns off
Replaced 301 80C 16A thermostat, purchased on ebay for $6.00, fixed problem. to Fix standing at front, Remove left side panel, two small screws hold thermostat in place. LifeSmart wants $36.00 for same part. Fixed problem.
Oct 18, 2013 | Lifesmart Renew Infrared Quartz Heater...
Eden pure beeps 3 times, and then it will not work
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Oct 09, 2013 | EDENPURE USA1000 Infrared Heater
A ERR comes up on my American comfort heater
Remove power for some time and switch on after few hours , this might reset any error on the processor , if not the error could be due to fault indication of a failure within the heater, could be the infra or the element.
Oct 02, 2013 | AMERICAN COMFORT ACW0035WE 1500W Infrared...
Lifesmart Renew Infrared Quartz Heater LS1500-4 1500W LS-HPTC15PB Logo
666 people viewed this question
Top Lifesmart Patio Heaters Experts
deton8 von Splosion
Tom Chichester
Are you a Lifesmart Patio Heater Expert? Answer questions, earn points and help others
