You will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
if this is gas it calls the induced draft motor to come on for 15 to 20 seconds to clear any residual gas before beginning the ignition process begins. Very normal and a safety feature.
Could be a faulty thermostat, but I would check that element is getting hot before commiting to replace the thermostat.
Run it for a few minutes and feel to see if you can feel hot air blowing from fan at rear of oven. If no heat present, thei it will be the elemnt that is faulty.
It will be the oven element that is faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Please leave feedback for my suggested solution.
Thankyou.
If it is the main oven blowing cold, then you need to replace the oven element.
This is located at the rear of the oven, behind a removeable cover.
This should solve the problem.
For all Free appliance repair videos visit our VIDEOTUTORIALSNefffan oven element video1, If the fan motorin the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter. To gain access to the NEFFelement you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the elementyou willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the elementis open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine. 2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motoris working you willsee the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven thenyou need To replace the oven fan motoris a little moreexpensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat 4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timerinto AUTO mode,simply put oven back to MANUAL mode and all should be working again.
If the fan is working o/k, then it is almost certain to be the element that needs to be replaced
This is located at rear of oven compartment, behind removeable cover.
Please rate my solution.
Thanks.
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
oven will not heat up only fan coming on
