Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Burner stays on high - Frigidaire Gallery GLEFM397DS Electric Kitchen Range
GE Spectra burner stays on high
if this is the one with the auto temp burner , defined by a sensor sticking up from its center , this maybe a normal condition for it without a pan on it , as I had one of these come on my new stove , as being a exe chief for 6 years id always set my flame height before setting the pan down , this feature took me some getting used too !!! to say the least !!
but now that im used to it , its great I love it , no more burnt on messes , works great with caramelizing things !!!
Feb 08, 2016 | GE Kitchen Ranges
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
Kitchenaid electric stove burner stays on high
The dials you mentioned are called infinite switches and if they control, or regulate should i say the amount of power applied to the burner, so those are the parts you need to replace. You can order online or go to a local appliance parts store, just make sure you take your model number with you, not the number in your owners manual but the model off the machine itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | KitchenAid Kitchen Ranges
One of the burners stays on high. can that be fixed?
Hello, Thank you for your post. Sounds like your having a problem with one of the burners on your cooktop. Yes, you can have this fixed. The burner that stays on high has a bad infinite switch. Once you change out that switch your cooktop will work as normal.
Happy Holidays!
Please rate me "4 thumbs" if this information was useful.
Dec 20, 2010 | Jenn-Air JED8430 Electric Cooktop
Range top front burner will not shut off, stays on high, back burner up button does not work and timer does not work. Even though it was fixed in Feb of this year LG will not fix it again
I have the same problem with the LG LSB5682SW Electric Range - Font Left Burner will not go off / stays on high. This is very dangerous. LG customer service is horrendous. I think it is time for a recall before someone's house burns down!
Jun 30, 2010 | LG LRE30755 Electric Kitchen Range
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Ge profile electric cook top 30in. all burners stay on high temperture
the controls for the burners are reastats, if they all are only heating on high and you cannot lower the temp the switche are bad
Apr 30, 2008 | Kitchen Ranges
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
116 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
