Microsoft Windows XP Professional for PC Logo
Posted on May 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My friend's windows xp cd is braked, how can i download it
I want to download WINDOWS XP PROFESSIONAL
bnty
Level 2:
Sniper:
  • Expert 61 Answers
  • Posted on May 01, 2009
bnty
Expert
Level 2:
Sniper:
Answers
61
Questions
0
Helped
21464
Points
192
U need that?? i can send u, i hv win xp servicepack 2 cd...
mail me @
[email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
72
Points
2answers
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
2answers
My system now window7 .iwant instaling window xp .but no awaiable boot iwant driver
You can download the latest version (sp3 2011) of windows xp from this link:
http://www.world4free.in/2011/02/windows-xp-sp3-2011-v-1102-full.html
After downloading, place a plane CD in the CD/DVD writer and then double click the downloaded file. Now the burning process will begin. After burning is successfully completed, you can use this CD as your boot disc. Follow the installation procedure as usual.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
1helpful
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
1helpful
I have a laptop that had windows 2000 professional installed on it. i had problems and had to reset it. I installed windows xp professional, and i used a friends product key. The computer now has...
Hello Coreymanis,
You need to purchase the windows XP CD to get the Genuine CD Key.
You can reinstall windows 2000 Professional if you have CD Key of it, but it needed the CD also. If your friend having the CD you can use that CD and use the CD key which you have.
I suggest not to install windows 2000 professional because this has been expired as per Microsoft and no support available in future.
1helpful
Changing windows 4 to windows 2000 xp
First off, there is a big difference between windows 2000 and xp.
She needs her windows 2000 install disks and to re-install windows. Then she needs to install her service packs onto it. Either that or upgrade to windows xp. Id suggest she upgrade if she has decent hardware(memory, cpu and hard drive space)
There is no shortcut or work around unless you want to start using pirated stuff, which is probably not a good idea since most of that stuff is just an avenue for viruses and backdoor programs.
2helpful
I want to install windows XP free through
its illegal: download bootable xp iso file from warez or any craks site google's ur friend
then burn a cd & install it
2helpful
Download windows xp trial
Borrow cd from someone. it will install 30 day trial.
Vista to windows xp prof., toshiba satellite l305-s5894
hello , friend its very easy to do that, steps are
1. insert bootable cd/dvd xp prof. cd.
2. But be cautious because the xp profsn doesnt contain the drivers for ata hard disk. so pls find on net the drivers for ata hard disk drivers, also update it in bootable xp profsnl dvd . recreate bootable dvd of xp with advanced bootable xp,
3. or find it from your friend with latest updates requirement. and do from it.
4. Boot from tht cd and start the installation.
5. once it i completed install all video, audio e.tc. drivers.
6. if you dont have that drivers pls download it from toshiba site by entering the toshiba serial no
We have purchased Microsoft Windows XP professional under the pro
Hi Mathew
You can download or borrow cd disk from friend if they have same version of xp and you can make copy of cd. Your product key is that makes it legal copy so its unsecure to post your key to internet forum or any public site.
Best wishes,
Chillimar
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
