RCA OPAL M4001 MP3 Player Logo
Posted on Oct 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows wont read the device
Well with the opal it has the internal battery ..when i first got my player it performed fine with my computer..unfortunately now im getting a windows error that says it cant read the mtp device and if i restart all i get is you can safely remove the hardware..ive tried reinstalling the opal using the provided disc but i still get the same error
  • Anonymous Jan 02, 2008
    it wont read the device.
  • jcool Jan 05, 2008
    where can I go to reinstall the usb drivers for rcam40002a
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Jun 18, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2178646
Points
14133
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
My rca opal m4204-a says initializing and thats it won't do anything else went to web site to check and can not fix it with thier instructions internal battery needs reset or something
As long as the computer enumerates the drive (you can see it in My Computer as a drive letter) then there is likely an issue with the firmware.
Download the firmware install from the RCA website: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
Be sure to back up any important media before performing this install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds.
This isn't really a immediate problem but I have my opal plugged into the computer now ans it won't read it ,it says on the mp3 player usb connected, tried unplugging it and pkugging it back in
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
-tHA mP3 dOCTOR
I have an RCA OPAL and it wont turn on
RESET didn't work
OPAL won't charge.
Get the firmware upgrade for the player. If the pc will not recognize, force recognition:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Help
If all else fails, check out http://support.rcaaudiovideo.com/
Opal Firmware (Version 1.2.8.0)
Executable File
Firmware: Opal M4004, M4008, M4018, MC4004, MC4008 and MC4018 Firmware
If you are experiencing difficulties with your Opal device and believe your firmware may be corrupted, use this file to restore the original (OEM) firmware.
Firmware v1.2.8.0 Enhancements:
  • Enhanced voice recording performance
  • Enhanced battery charging capabilities
Firmware v1.2.4 Enhancements:
  • Improved charging compatibility with Windows™ 2000
  • Improved user experience when shutting down
  • Improved the functionality of the “Menu” button
  • Added device screensaver (visible when connected via USB)
RCA OPAL M4001 MP3
Rca Opal
RCA opal
RCA Opal Not Recognized
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
