I cannot get the back of the watch back on it will not stay down
Hi Ken,
Some watches require even pressure all the way around the back at the same time to get it to pop on! You will need to have this done at a jewelry store or watch repair shop. Thank you! Lisa
Posted on Nov 07, 2013
Feb 25, 2017 | Timex Watches
Jun 13, 2015 | Watches
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
Apr 28, 2012 | Watches
May 27, 2011 | Watches
Feb 12, 2011 | Watches
Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
Apr 19, 2008 | Timex Ironman 53151 Wrist Watch
Mar 26, 2008 | Casio W94HF-3AV Wrist Watch
Sep 19, 2007 | Watches
Feb 17, 2021 | The Watches
32 people viewed this question
