Lexmark X2470 All-In-One InkJet Printer Logo
Question about Lexmark X2470 All-In-One InkJet Printer
Service manual The power to my printer went out in the middle of a print job. I can't get it powered back on. Is there a fuse on the unit?
Posted by William Harper on
5 Related Answers
Anonymous
  • 198 Answers
SOURCE: Lemark Z52 Inkjet
Hello, First of all, let's start with some simple questions. 1 Was the cartridge ever refilled or is it in the original state? 2 How exactly did this occured? I'm asking this because most printers have a limited space inside them for the cartridge to move around when printing. If they don't fit exactly as they should, they will most likely hit something in their movement when printing. If your cartridge was refilled maybe the person who did that didn't attached the cartridge top part properly and now it moved out of position and hits the inner top of the cartridge housing. Please provide me first with these informations so I can better assist you.
Posted on Sep 09, 2007
Anonymous
  • 1913 Answers
SOURCE: A designjet 700 with a black cartridge test on every print job
open the front door then pull the ink cartridge then cleat it from dust and ink then refix them.then try.
aslo check there is not any paper jam.
Posted on Jan 07, 2009
Ramel Mayormita
  • 240 Answers
SOURCE: Lexmark 2380 plus won't stop printing
i think its a firmware issue for me..
I experience it before with my printer ..
I just flash with another firmware..
and if the problem still exist..try to
uninstall printer driver and install another one.^_^
Posted on May 13, 2009
Anonymous
  • 54 Answers
SOURCE: After a power outage, the
Most likely its your power supply.
part # 56p1904
Manual ----> http://www.arbikas.com/view/locator/4038.pdf
Hope this helps
Posted on Apr 11, 2011
Anonymous
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark T640 LCD blank..
    To check if this is a hardware issue, please print a menu settings page. The purpose of this diagnostic is to check if this is a software issue or a hardware issue.
    1. Press Menu to display Menus.
    2. Press "down" until the "check" appears next to Reports.
    3. Press "Check".
    4. Press "down" until the "check" appears next to Menu Settings Page.
    5. Press "check".
    The message Printing Menus Settings appears on the display.
    The printer returns to the Ready state after the menu settings page prints.
    If the menu settings page printed without the dots, this would be a software issue. In that case, please call our Technical Support Hotline on (800) 539-6275.
    Posted on Aug 30, 2012
    Cartridge error 1203
    The 1203 error indicates either a communication failure between one of your cartridges and your printer or a short in one of the cartridges. Please follow the steps below to fix the problem:
    1. Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on. Did the error message return?
    Yes: Continue to step 2.
    No: Print a test page. If the test page prints, the error is resolved.
    2. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    3. Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
    Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
    No: Continue to Step 4.
    4. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    5. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
    Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
    No: Continue to step 6.
    6. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    7. Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
    Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
    1. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    2. Remove the cartridges. Clean the cartridge contacts (How to Clean the Print Cartridge Nozzles and Contacts Manually).
    Source: 1203 Error Message on the Lexmark X7170 All-In-One
    2helpful
    Hello.Suddenly my printer got out of service due to a problem titled "5200".What is the source of the problem ? thanks [email protected]
    Error 5200 - Print head temperature rise error.
    Try this two troubleshooting procedures. If procedure A does not work, go ahead to procedure B. You have to do A first before going to B.
    Procedure A (Power Cycle)
    1. Unplug the printer from the computer and the wall outlet.
    2. Press and hold the power button for 10 seconds to completely drain the power from it.
    3. Plug it back in to the computer and the power outlet.
    4. Turn on the printer and try printing. If no go, proceed to procedure B.
    Procedure B
    1. Switch on the printer, while its moving the cartridge carriage unit, plug out the power cable. Open the printer's cover.
    2. So, now the printer is off, and the cartridge carriage unit is located somewhere in the middle or any side. Pull it to the middle of the printer.
    3. Take out both cartridge from the carriage unit, and leave the "Lid" open wide.
    4. Now turn on the printer with the Lid still open. The carriage unit will now move to the left and to the right, and then stop again at the middle.
    5. Now, you can put back the cartridges according to the color code: C for Color, B for Black.
    6. Close the cover, and try to print a page.
    Please let me know if it works or not so that I'll get back to you as soon as possible. Just post in this thread so that I can reply to you right away.
    Thank you for trusting fixya.com
    CARLO
    2answers
    LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
    1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
    Reset Epson DFX-8500 Matrix Printer
    Remove power cord for at least 10 seconds AND delete print job manually from Windows(?) Open Control Panel>Admin Tools> Services. Stop print spooler service. Delete contents of c:\windows\system32\spool\printers folder, restart print spooler service, plug printer back in.
    2helpful
    Canon IP3300 sunddenly lost POWER in the middle of printing
    the piece of metal that connects to the power cable might have dirt on it, or it might have come loose from the printer's internal wiring, or a soldering joint in one of the chips might have come loose, and in that case you need to go to a specialist because there is no way that anyone but a specialist would be able to find a boken joint in the printer's myrad of circuts
    My printer jammed in the middle of a page and after I turned it off, pulled out the paper and turned it back mon its printing 1 line of jibberish and pushing out the rest of the page blank, page after...
    Your printer queue still contains fragments of your print job
    1. Remove print job at your computer if listed
    2. Turn off printer
    3. Disconnect printer power supply
    4. Reconnect printer power supply
    5. Turn on printer
    Your queue should be empty now.
    Printer stopped in the middle of a job with the reported error SC 555 Power On/Off and if it continues, call a service technician. They won't come becaue the printer is 5 years old.
    When the fusing unit is not
    running in the Ready condition,
    the pressure roller fusing lamp
    keeps ON with full power for
    100 consecutive seconds.
    Replace the fusing unit.
    1helpful
    Cannon i850 printer. Power went out in the middle of a job.
    have you checked you are getting juice into your printer.... possibly you have a blown fuse, check cables as that may be your problem
    Printer stops in the middle of a printing and shuts down
    Force the HP all-in-one to reinitialize by following the steps below:
    1. Turn the unit off by pressing the ON button.
    2. Disconnect the power cord.
    3. Wait five seconds, then reconnect the power cord.
    4. but before plugging the unit back in, press and hold the # and 6 keys on the HP all-in-one numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the all-in-one re-establishes communication with the computer, reset the language and country.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Top Lexmark Office Equipment & Supplies Experts
    Clive
    Clive
    Marvin
    Marvin
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
