I have replaced the ink cartridge to a full one. The system is still saying that it is nearly empty. Plus, the light is flashing.
You have to reinstall the printer as you first purchased it,realign it the whole bit.but most of these priters figure you change both at once but most people dont so the printer thinks its still empty.so take both cartridges out while printer is on ,shut it off count to 10,turn it back on.at this time it should prompt you to do the steps,follow them everything should be good.hope i helped
Greetings,
Light Flashing indicates ' Paper mismatch error'.This means the print path specified by the printer driver and the path in which the paper is loaded are different.Now you need to Load paper to the path specified by the printer driver.
This means that ition of the output tray is wrong. Just keep the output tray vertical with ground as refrence, lift it and bring back to horizontal position (or vice versa by pushing it down).
Regards,
TechSup1
