Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Maytag mav6457aww loud noise when spinning and water leak
Our washer is making a loud humming noise when spinning, water is leaking and it is going off balance
5 Related Answers
Anonymous
SOURCE: maytag spinning loud noise
bearings are bad need to replace
Posted on Mar 14, 2007
Anonymous
SOURCE: Maytag Performa Washer
What I found on my Maytag was the water pump went out. There is a metal ring under the pulley that fell and was grinding until it froze. Replacement is easy and can be done by anyone. You can buy a reasonable pump offline. Good luck with your repairs
Carol
Posted on Sep 20, 2008
Anonymous
  • 85 Answers
SOURCE: LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Posted on Dec 16, 2008
Anonymous
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Posted on Jan 13, 2009
Anonymous
  • 17 Answers
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Posted on Oct 24, 2009
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
When water drains and machine goes into spin cycle it starts to make a loud clonking noise. It sounds as if the drum is going to fly out of the machine.
I've experienced this on occasion. stop the washer, redistribute the clothes, etc. so it is evenly balanced. The "rocking" occurs when the balance is uneven.
Apr 10, 2011 | Kenmore Washing Machines
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Make loud noise during spin cycle
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
My washer does not spin and makes loud noise
Hi!!! You have a bad motor coupler replace and you should be fine..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
