HP Compaq Presario SR1650NX (SR1650NXED881AA) PC Desktop Logo
R
Richard C Plitt Posted on Nov 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have EMachine tower door will not open to install DVD
Coss
Level 3:
Genius:
  • Master 1,056 Answers
  • Posted on Nov 07, 2013
Coss
Master
Level 3:
Genius:
Answers
1056
Questions
Helped
299478
Points
3846
You can use a paperclip to open it.
On the front of the DVD you'll see a little pinhole; unrwist a paperclip and push the leg of the paperclip into that hole; it will manually push open the DVD tray
How do I insert DVD into the tower part of computer?
now this depends on what make pc you have.
if there's no fancy pop down cover in front of the dvd tray, there is a button just underneath it to the right that you press.
if there is a fancy door then you might have to press this on the bottom right or there's a button on the right hand side.
if all else fails, hold down the windows key and press E. in the window that opens, right click the dvd drive in the left hand list and select eject.
Where is the hole located to open dvd cd door
The small hole to put a pin or paperclip into is on the face of the DVD tray. It is there, look hard for it.
DVD door will not open to eject DVD
There could be 2 reasons, 1. Hardware issue 2. Software drivers:
Fixing 1: Hardware
Make sure the DVD is fixed properly in your tower ( I am not sure whether you are using a tower or lappi)
The direct solution is to put a pin i the small hole present on your DVD player. That should open the DVD door.
To fix the software part.
>> Try to update the drivers depending on the operating system you are using.
>> Download the latest drivers to check if it fix the issue.
>> Open the My computer >> Right click on the CD/DVD drive and select Eject, this will normally open the door.
Else, try to uninstall the drivers from Device Manager and then restart the PC once, this will reinstall the drivers once again by its own if your Windows is up to date.
Please do get back to us, if that does'nt fix.
3helpful
1helpful
How do I open the door to my CD/DVD player on my eMachine Tower. I use to know how but as an old lady I need help remebering now. please help
There should be a button just below the cd tray on the front of the tower. If I remember correctly, on E-Machines there is a black bar just below the tray, and the button is a small section of this bar. If you press along the bar you should find a place that presses in. That will be the button to eject the tray.
Another way to do this is to click on "My Computer", there should either be a link on your desktop, or in the start menu. In this window you should see your disk drive, usually "D:\". Right click on this icon, and there should be a menu option called "Eject", which will open the drive for you.
Thanks,
John Vickers
2answers
I cannot open DVD door. I am not sure what model my tower is and I cannot find manuel
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
4helpful
I emachine dvd rom/burner won't open how can i open it? but before it really do not play any dvd and then now it wont open.
Best regards,
Yavacotech
I purchased an emachine desktop at an estate sale that had a note on the tower saying it had a new had drive installed and never used. So I purchase it and brought it home, hooked it up and turned it on. ...
Is the 'New hard drive installed, never used' bit relevant? Open the tower, get hard drive...
PC bought at auction won't switch on ?? Anything is possible, from 'It's really an empty tower with a brick in it for weight' .. to any number of usual suspects.. The fact that most PC computer 's make a beep and light up stuff when switched on for instance relies on the presence of a working PSU.
Your diagnostic approach would begin there.
2answers
Emachine keyboard went out
hi
if you have to back up all the programs that u need it try to open your
desktop tower and then pull out the hardisk and then put it in other computer and installed your
driver of your keyboard and then out it back to your original tower!!!!
1helpful
2answers
I have a emachine w5243 tower the expansion drive won't open.push botton but still know
the expansion drive will open if you can hang a fingernail or something thin in the top of the door and pull. It only takes a gentle pull.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
