Question about Kicker Car Audio & Video
No sound out of speaker
Ive tried other amps and still no sound and its wired correctly
Posted by chris kenline on
curtis chappel
    New Friend:
  • 182 Answers
Must be blown
Posted on Nov 07, 2013
1 Related Answer
Joel Navarro
  • 79 Answers
SOURCE: Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Posted on Jan 22, 2009
Mixer recognizes input and lights show it but no sound is coming out, Ive tried several speakers and cords but nothing.
I am assuming this is a new unit. Take a 9V battery and momentarily connect it across the speaker wire, it must not be connected to the amp. If it makes a noise that indicates that the speaker is probably OK, if not you found your problem. You may want to take to the store where you bought it for help. Check: http://assets.peavey.com/%5Cliterature%5Cmanuals/116558_26336.pdf You can download the manual.
Mar 07, 2014 | Peavey PVi 6500 Powered Mixer
Alpine mrp m 1000 turns on, has a good ground, but no sounds from sub. everything is wired correctly, i have tried using a different speaker to see if its just the sub that is bad, and ive tried using my...
Is the amp in protect mode? Maybe a red light on the amp. I would also open the amp and check the RCA connections aren't loose. It's usually a solder joint. Swap the amp out as well. Or check your power wire. Sometimes amps come on when it gets remote power, but actually the power wire has a bad fuse or connection.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 04, 2017 | Alpine MRP-M1000 Car Audio Amplifier
Hi there, ive got a 4500 watt amp connected to the two 1500 watts subs i bridge the two subs and it sounds greater than any other sub that ive had before....BUT lately it starts to play up,the maximum of...
could have shorted coil, check resistance on each speaker and compare, should be rated @ 4 or 8 ohms, or disconnect both then run individualy to test output
Dec 30, 2009 | JBL GTO14001 Car Amp
Just bass through speakers attatched to amp
there is probably a switch that says lpf-full-hpf those are your low pass filter(only low tones) full which is all ranges of sound and high pass filter which when you want to hook up a set of mids or highs I hope that this helps u out
Apr 01, 2009 | Car Audio & Video
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Amplifier has no power and all the cables are correct. i tried another amp, and it goes into protect mode.
Hi!
I know you say all your cabling is correct and I don't doubt you at all. However, the problem you describe sounds an awful lot like a short or an impedance problem with your speaker wiring. Make sure that the ohm ratings for your speakers are correct for your amp, make sure that the + and - wires for each speaker don't touch each other (especially easy to do where they connect to the amp), make sure that no speaker wires are cut or crimped (easy to do if you are burying under a baseboard or something), and finally make sure that all the speakers are wired correctly and are in phase.
A good test procedure is to remove all speaker connections from the amp. Then run new (test) wires from the amp to just your front speakers or to two known-good speakers with correct ohm impedance. If the receiver works that way, it tells you that you have a problem somewhere in your wiring.
Good luck and please let me know if this helps.
Bob
Oct 09, 2008 | Audio Players & Recorders
Sony Xplod 1200w
Either the speaker is shorted out (blown), or the output transistors in the amplifier are bad. Try hooking up another speaker to the amp. If it plays, the amp is good. If not, then the amp is bad.
May 22, 2008 | Sony XM-1252GTR Car Audio Amplifier
Something Wrong With my Fosgate 500-a2 Amp
Is the amp being fed directly from the head unit's RCA preamp outputs or is it being fed by another amp's preamp outputs? Try temporarily wiring up a speaker you know is good in place of the sub and see if anything changes.
Apr 01, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Sounds problem
First things to check:
  1. You changed the fuses on the amp, but have you checked the fuse that is inline on the +12V wire? Most of the time, it's right near the battery terminal.
  2. Do you have +12V at the amp's power terminals? If not, either your +12V or ground line has a break or disconnect.
  3. Try taking a piece of wire and connecting it to both the remote connection of the amp and the +12V on the amp. This should cause the amp to turn on (if all is well). If not, the issue might be internal to the amp and would require professional repair.
Mar 13, 2008 | Directed 1100d Car Audio Amplifier
HELP please!
ok on the factory radio there is an adapter kit you can get that plugs into the back of the headunit and will push the sound to the subs i had one in my car till i got a new headunit and it worked fine. id recommend that you go to your local sound shop like a detail shop or some place that installs them for a fee and ask them what you think
Nov 05, 2006 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
Top Kicker Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
